598 Vistas, 2 Respuestas
AutoCAD 2014 Lt not working with High Sierra
Hope someone can help. I use AutoCAD 2014 Lt on a Mac for architectural drawing and apparently Mac OS High Sierra has updated the file system to APFS which makes this version or AutoCAD unstable. It seems I need to partition off a section of the hard drive to support Mac OS Journaled for older versions of software.
Has anyone done this? I believe it also affects 2015 version as well but 2016, 17 & 18 versions have been fixed.
J.FOCHT
en respuesta a: Anonymous
Older versions of Autocad were not designed to be compatible with High Sierra. Therefore, 2016+ work because they were designed to be compatible with High Sierra. It may work but that is why it gives you the warning that it may be unstable.
This AKN explains it also:
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/sfdcarticles/sfdcarticles/...
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
pendean
