maxim_k
en respuesta a: twhitwell6
There is another thing with -LAYMRG command in AutoCAD for Mac. It has a bug: objects you move to another layer and are inside block definitions, moved "nowhere": if you will open block with such objects in Block Editor and look at their properties, you will see "Multiple selected" in Layer property. If you will run AUDIT command in the drawing after using -LAYMRG command you will notice errors, if those errors will be repaired, objects inside block moved to another layer will be placed on $AUDIT-BAD-LAYER layer.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
