john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
The Block Editor only shows the information contained in the block. If it is a simple block, you might make a copy of it and place the copy adjacent to the are you are trying to see. Explode the block, make your editing changes and then make it a block again with the same name as the original. This will redefine the existing blocks in the drawing to the newly edited version.
John Vellek
