834 Vistas, 13 Respuestas
printing PDFs
Hi
Im trying to print a PDF and im just getting it in Black and White where as in my drawing i have aspects in different colours.
any tips to how i make it print in colour?
thanks
steve
pendean
en respuesta a: Anonymous
Post a screenshot of your full PLOT dialog box.
maxim_k
Hi Steve,
Verify you not using Plot style when printing, or use standard acad.ctb plot style table
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: pendean
Attached is what is on my screen but when i save as PDF or print its all B+W
en respuesta a: maxim_k
Hi Maxim
im not sure what you mean. is this something i can choose at this stage or is this something i should have started with?
how do i check this?
thanks steve
maxim_k
I mean this:2018-02-02_07-11-45.png
Plus verify that the color of the colored objects in your drawing is assigned from this color page:2018-02-02_07-12-18.pngbut not from True Color.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
That's not the PLOT dialog screen: this is what I was looking for https://forums.autodesk.com/t5/autocad-for-mac-forum/printing-pdfs/m-p/7745398#M30088
Hi Maxim
please see attached,, i cannot find the color page to veryfy this.. where do i find this..
cheers steve
maxim_k
The Color window I mentioned is not related to the Page Setup dialog window.
It is related to the object properties:2018-02-03_16-45-33.png
Can you share your drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Maxim..
thank you.. i have found this and checked the settings and i have tried to export as PDF by setting it to color by layer and by choosing the color and both made no difference..
is there any other options..??
many thanks
steve
maxim_k
Please attach your problem drawing here. I'll okay at it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
you need it as a DWG??
maxim_k
I get this result on my side, when I save to PDF your drawing - see attached PDF.
Please verify if you accidentally edited standard monochrome.ctb plot style table and assigned red color to Color 1 and Color 10.
For example if you have:2018-02-03_21-16-59.png
But it should be:2018-02-03_21-17-42.png
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Hi Maxim
no i havent changed any thing to do with colors apart from changing layer colors.
i have managed to print the doc now but by changing the plot style table in the page set up editor from monochrome to print as displayed. please see attached
i have also attached a screen shot of what my plot style table editor is set at
many thanks
steve
