2306 Vistas, 8 Respuestas
Reorienting model to face true north
I have generated a site map (2D) that is not oriented to the correct cardinal direction and I need to change this orientation - either by changing true north on my cube or rotating the entire site map I assume.
I appreciate your thoughts
P.S I am using AutoCad for Mac 2018
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Shyla,
Probably both solutions are suitable.
It all depends on what you are going to do next with this drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I am looking for direction on either option.
maxim_k
You can use ROTATE command with "Reference" option to rotate everything in your drawing to desired direction.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
Did Maxim's suggestions get the map oriented properly in your project? If you need additional assistance with this is is possible to add your drawing to a post and I am happy to take a look for you.
John Vellek
en respuesta a: john.vellek
Yes, thank you.
Maxim,
Thank you again for your solution to my original problem.  In correcting this successfully I realized I have another problem. My apologies if this is a rudimentary concept (am very new at autocad and drafting), but I am trying to orient my site to face the cardial directions generated from my compass, who creates North as 0 degrees and East at 90 degrees.  However, on my model north is oriented to the Cartesian X,Y plane, making North 90 degrees and East 0 degrees.
How can I  solve this discrepancy?
Thanks again,
SMyrick
maxim_k
SMyrick,
You can change the direction of the zero angle with menu Format -> Units...
Set it to North.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you again, Maxim.
