- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am using AutoCAD LT 2018 on a MAC. The one key shortcuts are not working. For instance when I hit "L" and enter nothing happens. I cannot draw a line. I have to type out "line" then enter. Also, it says it is "unable to find dictionary. Could not start speller." I already typed in "DCTMAIN" and "enu". That didn't fix anything. Do you think the whole program installed wrong? If, not how can I fix these things?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Have you tried to reinstall it or at least reset it yet https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/201...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I did reset the AutoCAD LT 2018. It said it was “successful” but when I opened the program nothing had changed. I still get the dictionary not found message and no one letter commands work.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to Autodesk Forums!
Hi Audrey,
Please verify that you have the following paths specified in AutoCAD Preferences:
The difference should be only in AutoCAD application name. I have full AutoCAD version,but you have AutoCAD LT, so in your case there should be "AutoCAD LT 2018" instead of "AutoCAD 2018" (in my case).
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There should be a screenshot in my reply. Do you see it?
(look at the screenshot of my post in the attachment)
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As you cannot see inline pictures in my post I attached it to this reply.
To open AutoCAD preferences window use menu "AutoCAD LT 2018" -> "Preferences...", then select Application tab and open the "Support file search path" tree to see what happens on your side.
Maxim
Maxim Kanaev
Architect
MARSS
