- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Without seeing what you have in your drawing this is a bit tricky to answer.
I suggest that first you set your dwg units with the UNITS command. It sounds like you want to set it to architectural
Then, as a means to help, I draw a 6x6 inch square in modelspace.
Now, I switch to Layout 1. I am going to apply a Page Setup that is using a Letter size piece of paper (8.5x11)
Next, I can resize my viewport by clicking on it and then using the grips to make it bigger
If I double-click in it I can enter the model. I can now set my scale for the view of the model by selecting 1:2 from the Scale List.
Now for the dimensions.
I like to apply a linear dimension to the square in modelspace so i can see what the current dimension settings look like.
The extension lines, arrow heads and text height can all be a bit bigger in my opinion so I use DIMSTYLE to modify the dimension style being used.
I go to the Arrow size (in the Symbols and Arrows tab) I will change to 1/4"
I will change my text size to 1/4" as well (Text tab)
I then move to the Primary Units tab abd select the Units Format and set it to Architectural
I like the way these changes look so I am going to keep this dimension style for later use. I can copy this one dimension and place it into my acad.dwt template file. Every time I start a new drawing based upon acad.dwt, this definition for dimensions should be present. Of course, it is a good idea to check the font being used and to give the Dimstyle a unique name before putting it into the template.
Let me know if this helps. If you can attach a sample of your drawing I am happy to look at it to help with these steps.
John Vellek
