320 Vistas, 2 Respuestas
Output problems to PDF - LT 2017 for MAC
I am trying to create a standrad layout that when output to pdf and then printed by the Client produces an A4 sheet with a solid border say 10mm away from the paper edge all round.
So far all my efforts have ended up with missing border or some being further away than others.
Is there a simple way of achieving this. All the title blocks and drawings will the . be located inside this border line.
Many thanks
Peter
pendean
en respuesta a: Anonymous
The PDF driver determines the margins, not you.
Is 10mm within the margins the PDF driver you are trying to use?
As a test, start with 50mm then work towards smaller margins until you find where that sweet spot is at.
maxim_k
Hi Peter,
Create custom paper size A4 with zero margins.
Create Layout with this custom paper size, compose your drawing inside sheet with 10mm margins.
Plot to PDF.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
