1175 Vistas, 11 Respuestas
Cant move (drag) objects with LMB on and cant pan with wheel (middle) button on.
Hi, I've asked on PC forums but they've directed me to here. I cannot drag objects with LMB on (only if I hold the grip points only) and I cannot pan with middle (wheel) mouse button on - only when holding space.
Here is the podcast: http://autode.sk/2DiKbQR
en respuesta a: Anonymous
Aha, the mouse is Logitech M557 and all the settings (that I know about) are correct.
maxim_k
Welcome to Autodesk Forums!
Hi Pawel,
@Anonymous wrote:
..I cannot drag objects with LMB on (only if I hold the grip points only)...
This feature is not available in AutoCAD for Mac.
@Anonymous wrote:
...I cannot pan with middle (wheel) mouse button on - only when holding space...
Do you have some special software installed for your Logitech mouse?
What settings do you have for mouse in macOS System preferences (Mouse pane)?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
I have the Logitech software installed and all settings in both CAD and this soft are as they should be as I've checked on other forums. I also uninstalled it and it was same.
maxim_k
Can you post screenshot of Mouse pane in macOS System preferences without mouse software installed?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
I've just reinstalled the Logitech software and that OSX mouse pane looks exactly the same.
maxim_k
I see from the screenshot that 3-rd mouse button is not fully supported on MacOS System level - there is no settings for it.
What happens when you click with wheel button? - In AutoCAD, when AutoCAD is not running.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
When I click it the cursor changes into a hand (like that pan hand), whenever I move it, the hand disappears and change back to a normal cursor - and of course I cannot pan the drawing.
maxim_k
Very strange behavior.
Does middle mouse button work outside AutoCAD?
What if you assign Mission Control action to it?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI @Anonymous,
Have you tried this same action with a different mouse?  Do you have a trackpad? Can you pan by using a two finger gesture?
If you toggle the space bar preference for Pan in Options does it change this behavior?
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or @maxim_k's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
