1576 Vistas, 6 Respuestas
Printing to 1:1 scale incorrect dimensions
I have an issue with the 1:1 scale printing at the wrong size. The drawing is a simple 2D that I print and use as a 1:1 paper template.
The first time I printed it the scale was correct, but the second time I printed (using the same print setting) the dimension were incorrect (out by about 5mm) and now every new drawing I print has the same problem! I have tried printing from both model and layout with changes to the page set up, but I can't seem to fix the problem.
I have attached a screenshot of the page set up and print setting. If anyone could help me fix this it would be greatly appreciated.
Thanks, Simon.
