977 Vistas, 11 Respuestas
Page Setup Dialog Box Partially Displays
When I plot and attempt to Edit Page Setup, I only get an incomplete Page Setup dialog box. I can't edit the screen, change plot styles, etc. I have to ESC to get the partially displayed dialog box to disappear.
AutoCAD LT 2013 for Mac
OS X V10.9.5
maxim_k
en respuesta a: Anonymous
Hi Marc,
I think you need to install all of these updates:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/downloads/caas/downloads/content/autocad-l...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thank you for the service pack links. It turns out I also needed Service Pack 1 (links below are 2 and 3). Page Setup Dialog Box now displays and works correctly.
There is one lost function I noticed after installing the service packs: one button scrolling disappeared. Usually, I hold down the "wheel" in between my two mouse buttons and it acts like a quick-scroll. That function is now lost. Any ideas? I use it frequently.
Thanks again for your help!
Best,
-Tracy
maxim_k
What happens when you click and drag now with the middle mouse button?
Please verify that system variable MBUTTONPAN=1.
Have you tried different mouse?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
When I click and drag the middle mouse button, it takes me to Mac widget dashboard. This is what happens when I'm not in AutoCAD.
Same result using different mouse.
I saw an earlier question you answered about holding down space bar or option key. Those work, just clunkier than holding down the wheel.
Also, MBUTTONPAN = 1
maxim_k
Go to macOS System Preference -> Mission Control pane and change "Show Dashboard" from:
to this:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
It worked. Thanks
tsaalman
Hello Maxim_K,
I'd like to install Autodesk on a Mac OS X 10.9.5 but I cannot find the base downloadable, only some update files.
Can you help?  Thanks, Todd
maxim_k
en respuesta a: tsaalman
Hi @tsaalman ,
You need AutoCAD 2016 for Mac (or earlier) for macOS 10.9, but this is rather old version.
I tried to use AVA:
https://ava.autodesk.com/modular/
but got the following message:
"Unfortunately, the product and/or release year you requested is currently unavailable for download. Please use the below options for more help."
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
Hi Todd,
@tsaalman
I have found it:
https://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-for-...
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
tsaalman
Thanks, maxim_k! I hope it works on my old Mac OS X 10.9.5 Mavericks.
Alternativrly, my 64 bit Windows 7 OS. Will try when I return to my desk.
