gizem.ulukardesler
5492 Vistas, 4 Respuestas
Cant change the layer of an block
 I'm having some trouble about changing the layer of a block. I'm loading the block here. Can you help me please?
pendean
en respuesta a: gizem.ulukardesler
You want toe content inside the block to be on a separate layer?
Or just the block be on a separate layer?
And what is the new layer name and it's properties?
Or do you just want help editing the entities of your dynamic block?
What is your AutoCAD for MAC version exactly?
gizem.ulukardesler
en respuesta a: pendean
I want it to be on a separate layer actually I just wanted to change its line weight to 0.09mm.
What is dynamic block? and im using AutoCAD 2016.
pendean
maxim_k
Hi Gizem,
Edit the block in Block Editor - change Layer of all objects inside the block to layer "0", save changes.
Now if you will insert the block to the Layer with Lineweight property set to 0.09 - the block elements will take 0/09 lineweight.
See attached drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
