maxim_k
en respuesta a: Anonymous
Hi Stephen,
You cannot do this with rectangle created with RECTANG command, because it is just a closed polyline and not an "intelligent" object, but you can try use dynamic block feature to accomplish this goal:
https://knowledge.autodesk.com/support/autocad-lt-for-mac/learn-explore/caas/CloudHelp/cloudhelp/201...
I attached drawing with such kind of block.
You can change rectangle dimensions in Custom section of the Properties palette:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
