en respuesta a: john.vellek
I just re-installed AutoCAD LT for Mac Version N.51.M.5 (2017.2 update) on my Mac.
Previously the print to PDF was an available printer driver in AutoCAD.
It now no longer is.  This was previously only an option in AutoCAD, so I don't think it was a MacOS printer, but it is possible that I am doing something wrong in the MacOS that is no longer making it visible.
My problem is that my available printers are small format - I would like to create large format (24' x 36", etc.) PDF's and I previously used the AutoCAD PDF printer for that.  I could select the AuotCAD PDF driver previously from "add a printer".  There also is no longer an option to create a custom size at the bottom of the printer paper size pull down menu of the available printers I do have.
I'm printing from model space and manually selecting a print area and drawing scale.
I fell stupid asking this - I'm pretty tech savvy but this one has me stumped because I have not had this problem in the past three years when I switched back to an Apple from the PC's I have been using for so many years.
Mahalo,
Bill
p.s. I started using AutoCAD in 1985 (and made the cover article of Candence magazine in 1986 or 1987 with the company I was at the time)  and use it occasionally for shop drawings, but I have not yet taken the time to master paper space.  This is the first time I have posted a tech support question and I have purchased many different versions of AutoCad over the past 32 years.
Etiquetas (1)
