ian
en respuesta a: maxim_k
Hi Maxim, I had to research how to do that haha
The attached shows a simple move, when I press and hold the shift button mid command, that's when the "enter new value for ORTHO" prompt occurs
I then right clicked to accept the mode change and moved in ortho
If you watch the ortho button bottom right, it toggles from off to on, which is correct - however when the command is complete it should return to "off" but it doesn't
In LT 2017 the button goes on and off according to whether shift is pressed, and there is no requirement for a prompt acceptance mid-command
Hope this explains
