441 Vistas, 2 Respuestas
Trial version not compatible?
Hello, We've dowloaded Autocad LT 2017 for Mac with a trial period of 1 month and worked on it yesterday for an urgent job. But this morning when we wanted to present the project, it was not readable on other computers (with Autocad latest version).
Is there a lock that unable us to use documents made with a trial version on other computers? Is it then possible to save them in another program to unable us to open it from other pc/mac's?
thank you for your answers. Julie
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Julie,
Drawings, created with trial AutoCAD version are absolutely the same as created with commercial version, there is no restrictions (locks).
If you cannot open the drawing and you are sure it was created in 2017 version, then it could be corrupted for some reason.
What kind of alert you see when you are trying to open this drawing?
Have you tried to use RECOVER command to prepare errors (if any) in the problem drawing.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Indeed. Problem solved !
Thank you :cara_con_una_leve_sonrisa:
