- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Using Autocad for Mac 2011. In scale 1:1 using mm as units of measurements I create a rectangle 500mm long x 1000 mm wide. Half of the drawing appears in and the other half, outside the workspace. When I try to zoom out to view it it does not allow as if it has reached a maximum zoom.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try to use ZOOM command with Extents option.
You can also use REGEN command when you reach maximum zoom level.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The other thing you can do when starting a new drawing is set the drawing limits which can be found in the menu 'Format/Drawing Limits'
I was always taught to do this by my AutoCAD teacher when I first started out, although I never use it anymore. It basically sets up a drawing area in the form of a rectangle to the size of your choice. So for example if I was going to open a new drawing for the purpose of drawing a house floorpan, I may choose to make the drawing limits 20000,20000 which will give me a drawing area of 20m x 20m. You would do this before you start drawing.
You don't need to do the above, I just thought it may be worth knowing if you are quite new to using AutoCAD. As always there is often more than one solution for every question.
