john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
AutoCAD 2015 for Mac is not supported or designed for High Sierra. I would be very careful running this configuration.  If you must stay with that version on the two workstations, I recommend down-grading the OS.
File format for AutoCAD 2013-2017 is the same so you should not have issues opening and sharing your files between these versions.
John Vellek
