maxim_k
en respuesta a: Anonymous
Hi Dylan,
In your case it is enough to check that you selected "Relative path" from "Path type" in the Attach image window, which appears after you select an image in "Open image" dialog:
This should work in all cases if even if you will move the entire Project folder to the new location.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
