11-08-2017
07:19 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-08-2017
07:19 AM
Yes, there is no Perimeter property, but I used Length property for that purpose.
>>>>I do not know if such a
>>>>tool exists but it should be fantastic if it does.
Yes, I think it is possible to create such routine using AutoLISP. I have one "homebrew" tool which I wrote a long time ago. I uses blocks with attributes which populated during user interaction with drawing: when I start this routine it asks for room number, then asks to outline the border of the room, then asks fot the room name and finally inserts a block with attributes populated during the first stage.
The drawback is that if the border of the room will be changed, it will not update the attribute values, you have to use the routine again to create new block.
Maxim
Maxim Kanaev
Architect
MARSS
Maxim
Maxim Kanaev
Architect
MARSS
