460 Vistas, 2 Respuestas
Mid-point between 2 points is unable to use
I am using 2017 LT student version, a few weeks ago the command mid point between 2 points is not working while the other command such as endpoint/mid-point are fine.
I have tried to uninstall and reinstall again but the command is still have a warning side
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi @Anonymous,
Can you explain in more details what happens, when you are trying to use command modifier (yes it is not a command, but command modifier) Mid Between 2 Points?
How do you use it? From the command prompt (typing M2P inside current command), or from the context menu, or using button on ToolSeta palette?
What do you see in the Command window, when you are trying to use M2P modifier?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
pendean
Walk us through a command sequence you use where M2P is used, let's see how you are using it.
