10-21-2017
10:38 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-21-2017
10:38 AM
ALIGN adds an angle when you add the angle as you select the aligning points.
Draw a LINE in your DWG file to the exact length of the known dimension in the image. Ideally draw that line starting at the start point of the known dimension on the image itself.
SCALE command with the Reference Option can then be used as explained here https://knowledge.autodesk.com/support/autocad/getting-started/caas/CloudHelp/cloudhelp/2016/ENU/Aut...
Post back if you get stuck.
