- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi Michael,
You need to do the following:
- Use AutoCAD preferences to "Reset hidden messages" on Application Tab of the Preferences window:
- Next time you will open the drawing with PROXY objects, you will get this dialog:
- Now you have two options:
1. If you will not check "Remember my choice" option in the Proxy alert window, you will be able to select how to show Proxy objects in the drawing each time you open it.
2. If you want proxy objects always show as objects, you can check "Remember my choice" option and select the first option: "Show objects when available". From now "Unsupported objects" window will not appear each time you open drawing and if the drawing contains proxy date it will always will show as objects. System variable PROXYSHOW will be always reset to 1
If you want to return "Unsupported objects" window back, you always can "Reset hidden messages" again.
Maxim
Maxim Kanaev
Architect
MARSS
