642 Vistas, 4 Respuestas
No DWG true file reader for mac and I can't open 2018 DWG from w dows
Can anyone help! The 2018 lt is not out yet very annoying .
pendean
en respuesta a: Anonymous
It will be soon, but in the meantime you can use the online free version of www.autocad360.com
john.vellek
Hi @Anonymous,
If you need an app instead of online viewing, @maxim_k found this one which works quite nicely. I don't believe however that it will convert to different formats.
John Vellek
Victoria.Studley
en respuesta a: john.vellek
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestions that @pendean and @john.vellek provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
john.vellek
Hi @Anonymous,
Might I suggest that you check out the the Pre-release version for AutoCAD for Mac 2018?  This beta is very stable and allows you to open 2018 format files. If you are interested, please check out the link in this other thread.
John Vellek
