S2kSean
en respuesta a: dgorsman
Thanks!
I've just started playing with the program but even at my most intricate piece, it would be simple in comparison to what I'm sure you all are producing.
So far my main 2 projects using AutoCAD need the holes to be very accurate. They have both been engine to transmission adapters so at the very least, center and dowel points need to be precise. My procedure may or may not have been "proper" but the last one worked out so I stuck with the same method this time haha.
I've basically taught myself how to use the program with the exception of the help of a few very helpful gentlemen on here, so it's been quite the learning curve. I'd like to become more fluid in it.
I do like the idea of working off a copy for some of the things I've done so far while just playing around.
