514 Vistas, 6 Respuestas
AutoCad LT 2017 for Mac
I just dowloaded program to new MAC.  All lines appear the same color, pink!
Why is this happening?
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Can you explain your problem in more details?
Do you see all lines in pink color in one of your old drawings?
Or everything is in pink color when you create new objects in the drawing?
If the latter, the reasons could be;
- the current Layer in the drawing has "pink" color assigned
- the current Color is set to "pink", but not to "ByLayer"
Can you attach sample drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
new lines on different layers show all pink.  no color layer properties are being shown.  attached file. Please help.  Look at pink lines in box above model space drawing.
natasha.l
Hello @Anonymous,
This seems to be regarding using the layer properties tool. You can assign any color to the layer you wish, take a look at the article regarding how to use this.
I will move this post to the AutoCAD board for more information.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
maxim_k
Hi Michele,
As I suspect, you the Color property for new objects in your drawing is set to "Magenta" ("pink").
You need to change it to "ByLayer".
 - Open Properties palette (if you have not done this) by using menu Window -> Properties Inspector or with Cmd+5 shortcut
- Ensure that nothing is selected in the drawing area
- Change "Color" property to "ByLayer"
You have now:2017-09-26_07-19-56.png
You need:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
HI @Anonymous,
I am checking to see if you have figured out the color issue in your drawing with the help provided in this thread.  If you are still having problems I am happy to offer my assistance. Please let me know your status on this issue.
John Vellek
