- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi I use AutoCAD lt to convert PDF floor plans into DXF files which I can import into IESVE which is an energy modelling software. However, although I did this successfully on the first few occasions I am now unable to get the PDF to convert so only have the page frame or any lines I traced on the plan saving as a dxf.
what am I doing wrong?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Mark,
Are you trying to convert now the same PDF which gave you good results earlier?
AutoCAD can convert to vector objects only vector data from PDF files, if PDF contain raster image, it will not be converted.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
These are different PDFs can't see why they are different to previous PDFs as saved in same way onto my computer or scanned in as PDF
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If PDF was created in AutoCAD, Adobe Illustrator, Archibald, Vectorworks, Inkscape Affinity Designer or similar vector based editor, then AutoCAD can convert such PDF to DXF.
Maxim
Maxim Kanaev
Architect
MARSS
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Did @maxim_k's explanation help you get the bottom of this?
If you feel like the PDFs you're trying to import were generated by a vector-based program, but the data isn't importing properly, feel free attach one here and we can analyze it.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi
Thank you for your responses.
I understand that AutoCAD does not convert PDF's to DXF unless the PDF was generated in autocad.
MArk
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
This is not correct.
There are a lot applications which can produce PDFs with vector data - Adobe Illustrator, Inkscape, Vectorworks, Affinity Designer, etc. And even MS Word. AutoCAD can import such PDFs.
Maxim
Maxim Kanaev
Architect
MARSS
