maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Cho Yin Law,
Are you about this window?
If yes, then even if you don't get it now, you can pick "Cancel" in the dialog box where you asked to pick missing SHX file and drawing should open anyway.
If you are not able to return back this window by resetting Hidden messages, you may try to trash Profile.aws file.
You need to quit AutoCAD then navigate to the
~/Library/Application Support/Autodesk/roaming/AutoCAD 2015/R20.0/enu/Support/ folder (for AC 2015)
or to the
~/Library/Application Support/Autodesk/AutoCAD 2016/R20.1/roaming/Support/  (for AC 2017)
~/Library/Application Support/Autodesk/AutoCAD 2017/R21.0/roaming/Support/  (for AC 2017)
and move Profile.aws to Trash.
Then restart AutoCAD and test missing window.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
