09-06-2017
01:22 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
09-06-2017
01:22 PM
Welcome to the Autodesk Forums!
Hi Lisa,
I think the problem could be in the font you are using in the drawing and how it is interpreted by PDF viewer.
But at first I want to ask you: have you installed all updates to AutoCAD 2017 for Mac from here:
If you have not installed the Updates - try to install them and then test PDF output.
The next question is:
Which font you are using in your drawing? Is it one of the standard macOS (or AutoCAD) fonts or third-party font?
And the last is:
How do you output to PDF from AutoCAD? Are you using Print - Save as PDF combination, or Export to PDF, or Batch Publish?
Can you attach your drawing here?
Maxim
Maxim Kanaev
Architect
MARSS
