652 Vistas, 3 Respuestas
stampa su formato A3
Salve,
non riesco a impostare la stampa su foglio A3. anche modificando le impostazioni generali il programma non permette di selezionale fogli di formato superiori all' A4, benché la stampante selezionata supporti il formato A3
grazie per l'aiuto
saluti
camilla inverardi
maxim_k
en respuesta a: Anonymous
Welcome to the Autodesk Forums!
Hi Camilla,
Which AutoCAD for Mac version are you using? Please specify also macOS version installed on your Mac.
What do you mean by "the program does not allow to select paper size"?
Do you see A3 paper size in the list of paper sizes in Page Setup window?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
Which printer are you using for your print job? Do you see the proper page size available in other applications?  Which version of AutoCAD for Mac are you using?
Have you tried using a different printer as a test to see if the size is then available?
John Vellek
john.vellek
HI @Anonymous,
I am checking back to see if my post or @maxim_k's helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
