08-22-2017
12:50 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-22-2017
12:50 PM
Hi @Anonymous,
Thanks for your reply. Could you try resetting AutoCAD LT for Mac? This should set things back to default and often fixes issues like the ones you're describing.
To Reset AutoCAD LT for Mac 2017:
- Click the AutoCAD LT 2017 menu in the upper left.
- Choose Reset AutoCAD from the menu list.
- When the dialog box pops up, choose Reset AutoCAD, and the program will reset for you.
Relaunch the software and test again. If the issue persists after you reset, could you post a sample file where the issue is happening, so we can take a look?
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
