344876
361 Vistas, 4 Respuestas
Read only but not locked
I have several 2009 Autcad files which I used on my pc.  I switched to a Mac and am using Autocad 2017 and when I try to open my files, they are all read-only.  How do I change this so that I can edit my files??
pendean
en respuesta a: 344876
read-only is an OS tag, not any program's setting: all software obey the OS on your MAC/PC for that tag.
Where are your files stored exactly? Or where were they stored when you moved them to your MAC?
maxim_k
Probably you have permission problems. Anytime you can use SAVEAS command in AutoCAD to save read only drawing to the new file, then edit it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
john.vellek
Hi @344876,
I see that you are visiting as a new member to the AutoCAD for Mac forum. Welcome to the Autodesk Community!
I am sorry that you are having problems with your older files In AutoCAD 2017.  Have you tried making   copy of the files and placing them directly on your hard drive? (No External drive or flashdrive).
If so, try putting a couple files from another application in the same folder. Do those open and save properly?
Can you attach a couple sample files for me to try on my Mac to see if I too have any issue with the older file version?
John Vellek
john.vellek
Hi @344876,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
