john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Thanks for the file.  I, like Maxim, opened the file and it measures fine. So Kudos to you for using Dynamic Input and getting the corners of your polyline in the correct spots.
I have included a quick video of how I checked the size. I use both the distance command and also Dimensions to show the size.
So, tell me please, if you erase everything except the one bottom left triangle and bring into your cutting application, does it still report a different size? If so, what size does it show? I wonder if there are settings for the cutting bed that are coming into play here.
Without knowing exactly what you are cutting, I suggest that you might also investigate Fusion 360  for this process.
John Vellek
