maxim_k
en respuesta a: Anonymous
Hi Andy,
I opened your DXF file and measured bottom left rectangle:
Command:  DIST
Specify first point:
Specify second point or [Multiple points]:
Distance = 147.0000,  Angle in XY Plane = 0,  Angle from XY Plane = 0
Delta X = 147.0000,  Delta Y = 0.0000,   Delta Z = 0.0000
Command:  DIST
Distance = 88.0000,  Angle in XY Plane = 90,  Angle from XY Plane = 0
Delta X = 0.0000,  Delta Y = 88.0000,   Delta Z = 0.0000
Command:
you see, that dimensions are correct: 147 x 88 units (mm in your case).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
