- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Just as a note, I too have experienced the same problem using AutoCAD for Mac 2017.
I have a few drawings, each with a number of 'B Size 11"x17"' drawings. I can batch publish them to the printer using the embedded page setup for each layout, and they will print out perfectly. However, if I batch publish to PDF the image is rendered a quarter inch (a little over 6mm) to the right on the page which results in that much being cropped from the right of the drawing.
If I go to each individual layout, open the print dialog, and either select the Print Preview button, or select 'Open PDF in Preview', or 'Save as PDF...', or 'Save as Adobe PDF' from the PDF drop down menu, the layout is rendered perfectly fine in the PDF.
As was mentioned, kind of a pain when, as a result, one then needs to PDF twenty pages individually.
If there are any ideas for me to try to correct this, I'll give it a try.
Mack
