Victoria.Studley
en respuesta a: Anonymous
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the last suggestion that @dbroad provided work for you?
  • If not, we may be able to help more if you tell us a bit about your setup:
  • Which version of AutoCAD Architecture (2018, 2017, etc.)?
  • Which operating system (Windows 7, 10, etc.)?
  • Which printer are you having trouble with?
  • Can you switch the page size for the default AutoCAD PDF (General Documentation) and plot to PDF without crashing?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
