1565 Vistas, 3 Respuestas
Command Tilde Short Cut
I have recently upgraded to AutoCAD 2017 from AutoCAD LT 2015. In 2015 if I used the shortcut: Command Tilde, to easily switch between the different autoCAD files I had open (This same shortcut works for most other programs on my computer such as Photoshop, Acrobat, Illustrator) However 2017 doesn't have this same shortcut. Does anyone know of a similar short cut or a way edit the shortcuts to include this?
Thank you for your help.
Etiquetas (2)
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
In 2017 version you can switch between File Tabs (opened drawings) with Control+Tab shortcut.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
en respuesta a: maxim_k
Thank you for your response.
Control Tab Switches between all files open on my computer (including mail or photoshop etc.) and requires opening each CAD file as if its a new program.
Is there a way to switch between the tabs (Image below)
maxim_k
It is Ctrl+Tab - I'm sure.
Command+Tab - switches between applications on Mac (Application switcher)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
