wei503
en respuesta a: earthsquare
To reconcile all laysers, you can select all(cmd + a) layers in the Layer palette, right click and select Reconcile Layer.
By default there is no unreconcile layers. Only when system variable layereval set to 1 or 2, will AutoCAD do this. It is used to evaluate all new layers added to the drawing. This system variable layereval is saved in the drawing file. So if you see this alert, that means the creator or editor of the drawing deliberately enabled the function for some reason.
Wei Ma
AutoCAD QA Manager
