pendean
en respuesta a: murphymoon007
And what is your LT version? Is it supported in MacOS 10.12.5 http://autode.sk/2eFUYrO
Where are you saving your files to? if to the iCloud Drive folder then you need to change the place where you put your AutoCAD drawings.
There is knowing issue with iCloud and AutoCAD for Mac - it creates duplicates each time when you use QSAVE command when drawings are inside iCloud sync folder.
FYI this is not the MAC forum, it is over there https://forums.autodesk.com/t5/autocad-for-mac/ct-p/3011
