maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi John,
As Dean mentioned in his reply, you need to change settings in LAYFRZ command.
OOTB "Block selection" is set to "None" option and if a block or an xref is selected, it freezes the layer containing that block or xref.
You need to change "Block selection" to "Entity" option in order to be able to freeze the layers of selected objects even if they are nested in an xref or a block.
Here is how it works in the command prompt:
Command: _LAYFRZ
Current settings: Viewports=Off, Block nesting level=None
Select an object on the layer to be frozen or [Settings/Undo] S
Enter setting type for [Viewports/Block selection] B
Enter Block Selection nesting level [Block/Entity/None] <None>: E
Select an object on the layer to be frozen or [Settings/Undo] XXXX
Layer "XXXX" has been frozen.
Command:
With the same way you can adjust settings for Viewports:
In paper space viewport use [Freeze/Vpfreeze] <Vpfreeze>: Enter F to freeze objects in all viewports or V to freeze an object in the current viewport only
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
