501 Vistas, 1 Respuesta
XOPEN COMMAND NOT WORKING
 Hi All,
Hope you can help, btw I am running Autocad Lt 2015 for Macs.
All of a sudden today, the XOPEN command is no longer working i.e. in an already open drawing I click on an x-ref on screen, right-click and click to 'open x-ref', but it does not open in a new window. In fact it doesn't do anything. I am able to edit the x-ref in place and can open the source x-ref file all OK.
We recently had a new server installed and so I have updated the x-ref file locations just to be sure but this hasn't helped. Any ideas???
Many thanks in advance.
maxim_k
en respuesta a: Anonymous
Welcome to Autodesk Forums!
Hi Stuart,
At first make sure the XOPEN works with xrefs saved on your local drive.
If it works, then the case could be in New network configuration, maybe permission related. Unfortunately AutoCAD for Mac is very sensitive to changes in network configuration.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
