maxim_k
en respuesta a: alexlaurenlilley
Welcome to Autodesk Forums!
Hi Alexandra,
The paper size you are using for the Layout is too small to accommodate your elevation drawing at 1:20 scale. From the 1-st screenshot I see that the scale of viewport is approximately 1:850. Assuming the paper size is A4, I can calculate that the size of the windows on the elevation are 27 by 47 meters (!)
Most likely there was a mistake in sizes when you drew the elevation in Model space.
Such big facade will not fit to A0 paper at 1:20 scale.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
