06-08-2017
10:20 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-08-2017
10:20 AM
Those were the troubles.
I didn't realize about the hidden view being frozen, and I must not have been in the view port when looking at the layers. I think I had the view port selected, but not actually in it.
As for the ties being a block in an array. That would be my fault. The parts are all components from other files, set up to be imported into various assemblies. So I'm sure I created a block for the tie in that file itself. Then when I imported it (or copied it in, don't remember which), I used an array to copy and space out the number of ties needed for the assembly. In this case, probably doesn't need to be in a block or an x-ref, so easy enough to deal with by exploding it.
Thank you very much. I appreciate it.
Mack
