06-03-2017
10:57 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-03-2017
10:57 PM
Hi Mack,
You cannot see:
- hidden hidden lines - because the layer with them is VPFrozen. It is VPFrosen by default as the AutoCAD Help documentation states: "Because drafting standards recommend not drawing hidden lines in sectional views, SOLVIEW freezes the View Name-HID layer." So you need to thaw the layer with hidden lines manually after you use SOLVIEW command.
- projection of ties - because the ties solids in your drawing are placed for some reason inside blocks and then inside arrays.
I attached drawing where I created new section (in red rectangle). I exploded "ties" to solids before performing SOLDRAW command and thawed HID layer after SOLDRAW command.
Maxim
Maxim Kanaev
Architect
MARSS
