en respuesta a: maxim_k
Hi Maxim,
Below is another image - all layers turned on. For the SolView, I did a section looking from the west. In it, you can see that there are the projections of the holes and the yellow spikes on that 2D projection. However, they do not appear on the paper space. (Also, oddly enough, the ties, which are dark brown and difficult to see, also are not represented at part of that projection.)
Also attached is the drawing file itself.
Thank you for your help.
Mack
