06-02-2017
07:33 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-02-2017
07:33 AM
Welcome to Autodesk Forums!
Hi Lindsay,
If you are trying to use Custom paper size you created, then double check it has correct dimensions. Or try to remove existing Custom paper size and then recreate it, be sure to type correct dimensions for paper width and height.
>>>>I also can't create a new drawing from within the
>>>>program. It only allows me to choose a template dwg
When you create new drawing in AutoCAD it always uses one of templates, that is why it shows "Select Template" dialog window when you use NEW command to create new drawing.
Maxim
Maxim Kanaev
Architect
MARSS
Hi Lindsay,
Maxim
Maxim Kanaev
Architect
MARSS
