351 Vistas, 2 Respuestas
Drawing/project info
Hi
As a small design studio, we don't use the project manager in Autocad LT for Mac.
We only use 1 dwg for the entire project.
Is there a way I can assign several info, like client, client address, project number etc, to this drawing?
So I can import all that info as a Field in my Title Block?
rkmcswain
en respuesta a: Anonymous
Since you are doing it all in a single drawing, one way would be to make a block out of the various items, then insert that block where needed on the sheets. If an update is needed, just edit the desired block, and all of the inserts will update.
en respuesta a: rkmcswain
Sounds a good solution!
thanks
