maxim_k
en respuesta a: lucianocapozza
Hi Luciano,
@lucianocapozza wrote:
By the way, the viewports look like 2d wireframe since it also has the soldraw command applied
OK, I see: the layer with the Solid object is VPFrozen, so it is invisible.
Anyway, I still cannot reproduce the issue you have on your side.
Looking closer at your screencast I noticed one strange thing:
After you pick the "side to view from" in SOLVIEW command, the crosshairs doesn't change its orientation to reflect the inclined plane - crosshairs remains "orthogonal", aligned with horizontal an vertical directions. But in fact, as soon as you pick "side to view from" crosshairs should rotate to reflect inclined plane:
I don't know why this happens on your side.
And additional question: can you reproduce the issue in every drawing or only in one, we are talking about?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
