tuskey
833 Vistas, 6 Respuestas
2017.1 - layer list vs layer palette
Now that the layer list is included in the layer palette in 2017.1, is there a way to keep the layer list above the properties palette while also having the floating layer palette open? I could do this with 2017.0.1. I often work this way -- layer list for a quick change to a single item and the layer palette open on a second monitor for freezing a group of layers temporarily, making a "global" layer update, etc.
I realize there is a layer pull-down menu in the properties, but as discussed previously ( https://forums.autodesk.com/t5/autocad-for-mac-forum/properties-palette-autocad-lt-for-mac-2017-1/m-...), Layer is beneath Color, which is unintuitive,  and plus there is not the ability to adjust color, freeze/thaw, or adjust visibility in this properties pull down.
If this is not possible, can it be made to be in a future update?
