lucianocapozza
1327 Vistas, 17 Respuestas
Problems with the auxiliary solview command
Hello people, I turn to the forum to see if any of you can help me with a little problem that I have and after several days trying to solve it, I do not get to anything.
The theme is that after modeling a 3D object, and performing the 3 fundamental views with the command solview - UCS and solview - ortho, without any problem, when wanting to make an auxiliary view of an inclined plane with the command solview - Auxiliary, when the view is projected, is not perpendicular to the projection line, but remains orthogonal, like a frontal view, or superior. I do not know if I explain correctly, but if they wish I can post an image so that they understand me better.
Thank you very much for your help !!
CLARIFICATION: I'm using AutoCad 2015 for students at MacOS
